Results 1 to 7 of 7
Thread: I own the TF-100xl with SpeedStir and Taylor K-2006c
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Hello. I was running out of some reagents for the Taylor K-2006. I decided that instead of ordering reagents for the Taylor kit I will order the TF-100. I did it. Some things are not the same but that is not the question.
    The question is about both kits having the same reagents numbers.
    Can I use the reagents that have identical numbers on any kit? (Some are not labeled Taylor but the reagent numbers are the same).
    I know reagent R-0600 and R-0014 will be only for the TF-100. But am not sure about the rest. Not that I will use that kit a lot because here in FL I will maintain the CYA at 60 meaning I need to do a daily test with the reagent that give me the high readings.
    Sorry if the question was ask before. I did a research but did not find an answer.
    Can I use the SpeedStir to mix some Taylor-K2006 test?
    Thank you in advance
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: I own the TF-100xl with SpeedStir and Taylor K-2006c
    Yes to all of it. They're Taylor reagents, just in better quantities rather than identical sized bottles.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    The TF100 uses taylor chem's just a better amount for how we test TFP pools
    you can use the speedstir on any of the tests, isn't it awesome
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Good.
    So when I run out of reagents I just order the same reagent number knowing that it will work on both kits.
    Thank you !
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by cowboycasey View Post
    Thank you!
    38,246
    I think the only difference is the pH reagent. Note that in March there is a sale on the TF-100 refill kit
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Thanks.
