Thread: Trouble filling up
    May 2016
    Brooks, GA
    11
    Trouble filling up
    First off, thanks to everyone who helped me in my previous post. Now my problem lies in filling the darn thing. I am filling off my garden hose ran from my house, city water. The problem is, the hose keeps popping out of the pool. I thought about taping a weight to it to keep it the water. It has done this twice on my today. First time we left it running while we were gone and I don't know how long it was out but there was about 2 inches of pooled up water next to my pool on the outside. Do you think this might cause a problem with the stability of the pool? We promptly created little trenches to flow the water away from the pool. The second time happened during dinner and wasn't as bad as the first.
    Once again, Thanks
    Bill
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Re: Trouble filling up
    Got a brick or large stone you can use to hold the hose down (padded underneath with a towel or something)?
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    What kind of pool is it Bill? I used a spring clamp from home depot (HDX 2 in. Spring Clamp-80002 - The Home Depot) on my ultra frame intex pool. I've also woven the handle of a broom between the legs and holds the hose in nicely
    I made a mistake a year ago filling my pool.....ran the hose into the pool....the hose almost touched the bottom of the pool. Turned on the spigot to fill....filled several hours, then wanted to give my well a break. So i turned off the spigot and unscrewed the hose from the spigot (house side) to plug in another hose for another project, but left the other end still int he pool....well...as you can guess, i came out the next morning and saw the pool was almost totally drained lol the water was siphoning out of the pool via the water hose due to gravity
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I used a shoelace to tie mine on the the railing (metal frame Intex), but you could do the same on the ladder if it's installed. A little redneck, but it works!
