Thread: Tons of footprints in new pool
    May 2016
    HUntington, NY
    13
    Had a vinyl pool built this spring. The sides are concrete, the bottom is sand. The builders were, overall, not so reliable. We finally got the chance to use it today for the first time, and my 10 year old niece spent about an hour frolicking in it. The floor has a lot of give under it.
    Turned the lights on tonight and the floor looks like a moonscape. Not just a little dent here or there, but dozens and dozens of dents and footprints. This is my first pool, but I've never seen this before.
    Does this look at all normal?
    Mike
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Tons of footprints in new pool
    Welcome to TFP Mike
    I have not heard of an inground vinyl with a sand bottom, most are done with vermiculite (a type of concrete)
    What you are seeing happens all the time in an above ground pool with a sand bottom..
    Are you sure they just used sand?
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,093
    I'd like to first off welcome you to TFP!
    Looking back at all the inground vinyl pools I cannot picture a single pool that didn't look like the moon when the lights were turned on. What you are describing is very common. It won't however harm anything besides the looks of the pool.
    May 2016
    HUntington, NY
    13
    Thanks to both of you for the replies. I'm new to pools and the forum, so not always sure what to expect. If it doesn't put stress on the liner, I won't worry.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    My installer sent a LONG time and tried SO hard to get the floor flawless. It looked awesome in the day light. Once night came and the light was on LOL not so much. Nature of the beast and does not affect anything. Those little dips will catch dirt and stuff in the just so you know.
    Kim
