My first TF100 kit arrived a couple days ago, and I managed to get some test results this evening. I've been adding a gallon of bleach (8.5%) for almost a week, except for the last two days I've been adding a gallon of 10% I picked up at Walmart. There are a few light green spots on the pool, so I know a proper SLAM is in order, but here it goes.
TC 4.5
PH 8
FC 4
CC .5 (it turned clear with 1 drop, so I went about the test. About 90 seconds later I noticed it had turned pink again. Not sure if that means anything)
CH 875
TA 100
CYA 20 or higher (was close to filling the tube and could barely make out the black dot)
My water is never really clear, which may be due to the CH being so high.
What do you guys think I should do next? For now I'm just in the holding pattern by adding bleach nightly.
TC 4.5
PH 8
FC 4
CH 875
TA 100
