Results 1 to 8 of 8
Thread: New pool and I'm clueless
    emaschke84's Avatar
    Mar 2016
    Blackwood/NJ
    35
    So, Filled up new pool, builder sends out their start up guy, who really appeared to be winging it. My TF100 is on order, but they gave me test strips. They dumped eight 40lb bags of salt in, turned on pump, added DE, gave me a quick course on the pump functions, and left. After running the pump for 10 hours straight, the pool looks crystal clear, I used the test strips and came up with the following:
    Free Chlorine-0
    Bromine-0
    ph-7.8 (ok)
    Total Akalinity-80-100 (ok)
    Stabilizer-30-50 (ideal)
    Unfortunately, until my kit comes in, I am unsure if I have enough salt which I assume is necessary for the generator to convert it to chlorine or if other levels are good. In the meantime, do I shock it to get chlorine up? Any advise would be helpful. Thanks.
    18'x35' 11k IG Vinyl 3.5'-5.5' with 9' sun deck and xtreme slide
    Pentair DE FNS-36, Pentair Superflow 1.5 hp, Simple Blue SWG 25000,
    Pentair Intellibrite 5G LED, Aquabot JR Z1, TF-100, K-1766
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: New pool and I'm clueless
    I would suggest you get into the PoolMath application found up top and use it to tell you how much liquid chlorine (plain old household bleach) and bring it up to about 4ppm (treating it as if it wasnt a SWG pool yet) and maintain that until the test kit comes and you can confirm how much CYA you have as well as everything else. Do it pronto so as to avoid any algae taking hold.
    You want to let us know these tests when you get the kit:
    FC
    CC
    pH
    CH
    TA
    CYA
    In that form, it is easiest for us to review. You'll also want to have Taylor's K-1766 Salt Test kit to verify your salt levels as you start to crank up the SWG.
    Start reading Pool school articles too!
    Yippee
    Aug 2014
    Northern IL
    4,615
    Do you have any bleach or liquid chlorine (liquid pool shock)? If not, get some.
    Here is the link to the guidelines for how to maintain the correct free chlorine to CYA ratio:
    Pool School - Chlorine / CYA Chart
    If you click on PoolMath above, you can enter your numbers (even though they are from guess strips for now) to know how much chlorine to add.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    In the long run, I think you're better off that the guy was a slacker. It's more work for you, but at least it'll get done right and you won't have to undo someone else's mistakes.
    I suspect the strip is wrong and that you have zero CYA. And in that case, the SWG will never be able to keep up with the demand. If the SWG isn't displaying the Low Salt warning, it's probably got enough. Give it a hand with some bleach. With no CYA the target is only 3, but it'll disappear pretty fast with no UV protection.
    emaschke84's Avatar
    Mar 2016
    Blackwood/NJ
    35
    Ok, adjusted my gallons, as it appears I have a 12K pool based on meter readings. Added 75 oz of bleach. I will re-test in the morning and see where we are at. Thanks for the info!!
    Aug 2014
    Northern IL
    4,615
    Best of luck! You are very fortunate to have Richard following your progress.
    emaschke84's Avatar
    Mar 2016
    Blackwood/NJ
    35
    Good morning all, tested again (still waiting on my TF-100 so using strips), the results are as follows.
    FC-5
    PH 7.8
    TA 120
    CYA-0
    The salt generator was set on boost (100%) by the pool company yesterday, so I am not sure if that added to the FC as my goal was 4 (missed Richards reply with goal being 3) hopefully it burns off as I can clearly smell bleach on my arm after it being in the water. It looks like my TA is high, and CYA non existent. Is there anything I should do at this point?
    Richard320's Avatar
    Jan 2010
    19,071
    Leave a nasty voicemail for the builder and inform him you'll be adding your own CYA so he better not show up and mess with your chemistry. Then do it.
    Your 5 FC will all be gone again today, probably by noon, despite the SWG on full blast, just from UV degradation. If so, then my hypothesis is correct and they forgot to add CYA. Add some. Besides stabilizing the chlorine so it doesn't all go away in sunlight, it's mildly acidic and will help keep pH from climbing and will lower TA a little bit as well. A three-way win!
