Thread: Sand filter pump sucking my skimmer plate in
    May 2016
    Abilene
    2
    Ok, I was trying to get my pool clean and ready for this Memorial Day weekend. I have an Intex Pro Series frame pool, 16x48 5,000+ gallons. I have a 2650gph sand filter pump with salt water system.
    The problem I am having is that when I put my skimmer plate into my skimmer to vacuum out the pool, the suction is so great that the skimmer plate collapses in and the skimmer even gets sucked in. It looks like an empty soda bottle when you suck the air out. I checked all my hoses, no cloggs or anything to cause it to try to suck everything in. Everything is flowing fine until I put the skimmer plate on with the vacuum hose attached. Idk what to do to prevent this. Can't clean the bottom of pool if I can't suck up the dirt. Any ideas??
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Sand filter pump sucking my skimmer plate in
    Welcome to TFP
    We have seen that problem before, the skimmer is made from very cheap plastic and just can not handle the suction with that pump and vacuuming..
    Most change out the skimmer like I did in my sig below
    Intex Ultra Frame - replacing intex pump with a Hayward
    Cutting Larger Intake Return holes in your Intex
    Thru Wall Skimmer Install. Above Seam With Intex Hoses
    Adding a Hayward Thru-the-Wall Skimmer to Intex Metal Frame Pool (PICS!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    You just have a lot of suction. Since the skimmer plate is junk anyway, this won't hurt. Drill a relief hole in it. Start small, maybe 1/4" That might reduce the suction enough so it doesn't collapse but still provide enough pull to vacuum. Enlarge it if you need to. And if the experiment fails, so what? You needed a stronger vacuum plate anyway.
    Jul 2013
    Fletcher, OK
    3,353
    good catch Richard, I was thinking the skimmer not the skimmer plate
    May 2016
    Abilene
    2
    Any suggestions on a different, more sturdy skimmer plate??want to know in case the relief hole doesn't work out.
    Thanks for the idea.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Pooldummy1989 View Post
    Not from me. I like to live dangerously and connect the vacuum straight into the suction port, with a PVC plumbing adaptor to keep the hose collar from getting sucked in to plug the pipes.
    This is actually upside down. The hose slips over the skinny part and the coupler fits down inside the hole and rests on a lip.
