Thread: Variable speed pump and pool timer
    May 2016
    South Florida
    3
    First post... I installed a Hayward Salt System today. The intermatic pool timer was beat and part of it snapped while I was pulling the wires. It's a 220 volt.
    I have been thinking of getting a variable speed pump. My little 1hp for my 13,000 gallon pool has a hard time moving the vacuum while the skimmer is on.
    Anyways, before I spend $60 on a new pool timer - do the hayward variable timers get wired with constant power? Or do I still run/power it from the pool timer?
    Thanks in advance!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Re: Variable speed pump and pool timer
    Variable speed pumps have built in timers and should be wired directly to a circuit breaker.
    May 2016
    South Florida
    3
    So then do you wire the salt system control box to the pump? Or breaker as well?
    DFW, TX
    24,504
    No, my SWG is wired to its own timer and I set it to run inside the run window for the pump.
    May 2016
    South Florida
    3
    So how do you get them to kick on at the same time? I mean I'm guessing they're "close enough"?
    Correct me if I'm wrong but I don't want constant power to the sale system right?
    DFW, TX
    24,504
    That is correct, the SWG should not be powered up when the pump is not running, they can explode from gas build up.
    I check the times from time to time to make sure they are synced up. Then I always set the SWG to come on 20 or 30 minutes after the pump starts and the SWG always turns off well before the pump shuts off because I run my pump a lot more than my SWG. Pump is running sun up to sunset right now for solar heat. SWG runs 7 or 8 hours.
