Results 1 to 8 of 8
Thread: hey im steve
    May 2016
    enola pa
    5
    hey im steve
    Hey I have been a pool owner for 7 years. 18 by 36 salt water. Seems like every time I go to have my water checked I'm told something different to buy at every place. Also been having trouble with my Pentair easy touch panel this year.
    May 2016
    enola pa
    5
    Re: hey im steve
    HELP cant figure out how to ask a question or make a post
    I have a Pentair easy touch panel and I'm having trouble
    hi I have a inground salt water pol 18 bye 36 vinyl lining
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: hey im steve
    You figured it out. I see two posts.
    Welcome!
    Ask away. But if it's technical about programming, it may be a while for a response. You can try the search box up in the corner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: hey im steve
    Welcome to TFP!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,245
    Re: hey im steve
    Hey welcome Steve.
    The best methods for caring for a residential pool are found right here. Here is a great place to start...
    If you want a safe and sparkling pool that is always ready for swimming, stay out of the Pool $tores. I suppose there are good ones somewhere in the world, but an astounding number of the 100,000+ members here at TFP have experienced the same as what you describe.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Casey's Avatar
    SW PA
    10,444
    Re: hey im steve
    Welcome Steve!
    May 2016
    enola pa
    5
    Re: hey im steve
    Wow I'm having so much trouble with this site .I'm not very good with computers.Im having touble with my Pentair easy touch panel I'm desperate for help.Where should I check or make a thread asking for help THankyou
    Hello casey Can you steer me in the direction or site where I can get help with my Pentair easy touch panel. Been on phone with Pentair zero help had pool company come out today zero help
    Richard320's Avatar
    Jan 2010
    18,995
    Re: hey im steve
    Quote Originally Posted by thebaum View Post
    Try clicking this to post a question about your automation.
    You might also try using the search function in the upper right corner.
