Thread: Intermatic timer digital display not working
    Feb 2015
    North Alabama
    58
    I have a digital timer that looks like this:
    Amazon.com: Intermatic PB313E 24-Hour 16-Amps 120-Volt Electric Timer: Home Improvement
    The digital display stopped working today. It appears to be functioning, because pressing the on/off/auto button does turn the pump on or off. And the red power light is on. But nothing is on the display.
    Do I just need to replace it? Looks like a fairly cheap part on Amazon?
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intermatic timer digital display not working
    I looked and it said it was humidity resistant but nowhere did I see waterproof or outdoor.. where is it installed?
    If it has lasted for awhile it should work again
