The “Generating” light stays on when the switch is in “Auto”, even when it is in the off part of the cycle.
The amps and instant salt went to zero, which indicate that it is not generating (meaning that it is now in the OFF part of the cycle).
Everything looks like it is working correctly.
What are your readings for fc (chlorine)and cya (cyanuric acid)?
3300 (Average salt)
81 (Water Temperature in F)
31.1 (Volts DC) (Correct voltage when not generating)
0.00 (Amps) (Correct when not generating)
5p (Percent)
-0 (Instant salt) (Correct when not generating)
AL-0 (Product name)
r1.55 (Software revision)
t-3 (Cell type).
If your pump ran 24 hours a day and the cell was set to 100%, about 7.2 ppm of chlorine would be added per day. That would be too much for a normal day.
For a pump run time of 24 hours, a setting of 25 to 50 % should be enough for most days.
Not sure why your chlorine is so high.
Leave it off until your fc is about 10% of the cya and then turn the output percent to 25 % and see how that works.
