Thread: Opening Numbers - First Time Opening
    Aug 2015
    Manalapan, NJ
    12
    Hello everyone. Opened my pool at my new house for the first time today. Everything went well with the open. Water's a little cloudy, but the filter is doing its job so far.
    Here are my numbers.
    FC - 5
    pH - 8.2
    TA - 160
    CYA - 30
    I know the pH and TA need to come down. There's an article in Pool School that basically says to take the pH down to 7.2 and then bring it back up through aeration. I have a return jet that can be plugged which would divert the water to another return jet above it which is above the water line, thus spitting the water into the pool like a fountain and providing aeration. The pool school article says the muriatic acid will bring down both the pH and TA and then the aeration will raise the pH without affecting TA. Is it that simple? Any other tips or advice would be greatly appreciated.
    Thank you all for your help!
    Brian
    27,0000 gallon In-Ground Plaster Kidney Shaped Pool - Approximately 30 years old
    Hayward Superpump
    Hayward Pro-Grid DE4820 Filter
    TF-100 Test Kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,350
    Re: Opening Numbers - First Time Opening
    Yup, its that simple although it may take a few doses of MA to resolve the high TA.
    How is your CH? You didn't list it. And do you have zero CCs?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Yes, it is pretty simple to use MA to lower pH and TA. Your pool with find a level it likes for TA that keeps the pH steady. Try lowering the TA a couple of times and bring the pH back to 7.5, then wait a couple of days to see if your pH remains stable. The only reason to adjust TA is to find the level that keeps your pH stable, so don't worry if the number looks "high" or "low".
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    You got it. No need to dump in acid to lower TA and then add pH Increaser to raise pH back up. Believe it or not, people have reported pool stores advising just that!
    Aug 2015
    Manalapan, NJ
    12
    Thanks for the help everyone. Just checked my other numbers. Kiddos were distracting me before.
    CC - 0
    CH - 400
    Should I be worried about the high CH?
    Thanks again.
    Hayward Superpump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    19,008
    Quote Originally Posted by BigBri594 View Post
    CC - 0
    CH - 400
    Thanks again.
    No. And there isn't much you can do about it but drain off a bunch of water you probably just added. 400 CH is easily managed. Be generous when it's time to backwash and you'll lose some then.
