Thread: Main drain with port in side- pool spa combo
    May 2016
    Seffner, fl
    3
    We have a pool spa combo . The spa has a main drain with a port on the side. The main drain is capped and it looks like the port on the side of the main drain is also capped ( in the spa) . We bought the house and have never owned a pool so we are not sure how to operate the spa. The spa has its own dedicated pump. We are trying to figure if the current set up is correct. Why would the main drain in the spa have a cap/plug in the bottom and the port on the side also be closed/capped? My husband uncapped the main drain and the pump them filled and seamed to work properly. However the suction is tremendous even with anti vortex drain cover in place. We then replaced the cap in the main drain and figured the port side is what should be uncapped. So the question is... Why would the main drain in the spa be capped in the bottom and at the port on the side of the main drain? Where does the port on the main drain run to?
    Seffner Florida 20k gal, IG cement , 1.5 HP pump, sand filter.
    Apr 2015
    tucson, arizona
    1,135
    Re: Main drain with port in side- pool spa combo
    Usually with a drain at the bottom and one in the side, that is known as split suction. They would be tee'd together and run back to the a 3-way valve. With both drains working there is less chance of entrapement. If the spa has a second pump ,that would be for the jets and would need another source of suction.
    May 2016
    Seffner, fl
    3
    Would that mean that the bottom should be capped and the side port open? Would the side port be what provides the suction?
    May 2016
    Seffner, fl
    3
    Quote Originally Posted by kadavis View Post
    Apr 2015
    tucson, arizona
    1,135
    It means that both drains should be open so the suction is split between them. As you have said with only one uncapped the suction is to strong. This is only if both bottom and side drains are teed together and have dedicated line back to pump. Maybe a picture of the spa and equipment could help
