Results 1 to 7 of 7
Thread: Clean Pole Recommedations Wanted
    May 2015
    Moorpark, CA
    171
    My extending cleaning pole collapses on itself when I push it along the pool floor during brushing. Anyone have recommendations for a pole that doesn't do this?
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,545
    Re: Clean Pole Recommedations Wanted
    I've tried several poles and they all have the same basic design problem. They adjust by turning a threaded PVC-like ring on the outside of the handle. They work great.... for about a month and then the threaded area gets dirty, or something, and starts to bind up. It will either fail so you can't turn it at all, or it will not tighten enough and does exactly like what you are complaining about...
    Went to my local pool store, not associated with any brand name pools stores, and they suggested I use a pole they carry. All the workings are inside. So I bought it (about $35) and I could not be happier. I was impressed enough to buy another one a few months later. At the time I did not look at the brand name, I didn't really care until I read your post.
    I went out to look and was surprised that it was a "Pentair" product. I didn't even know they had a pole product. Under the Pentair brand is the name spelled, "Lifegard #812-16 Tele PL R191046). I've only had them about 6 months, so time will tell, but, so far, they are way better than any other telescopic poles I have ever owned.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Quote Originally Posted by Michael1 View Post
    I just drilled a hole in mine and used a hitch pin clip - looks a lot like a giant safety pin - to keep it from pushing in. After I bent that pole by using the wall whale with the flap set too high, I bought a new pole just the same. It stays fully extended all the time and so far hasn't slipped. I think that's because it never gets adjusted. The other pole was sawed off at the bend and now I have two poles. The short one works good for brushing the spa and using the skimmer net, the long for brushing and vacuuming.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    I always enjoy reading your posts Richard. Spot on.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Quote Originally Posted by Jimrahbe View Post
    Michael you explained the problem perfectly! Good to know I'm not the only one!! I have this same problem with my prev. 3 poles and it drives me nuts. Was just struggling with mine today. Of course these smart folks always have a solution.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Yuma AZ
    71
    Here is a couple of photos of my setup. Drilled 1/4" hole through outer and inner poles and used this quick release pin to extend and collapse pole. The inner pole is 4 feet of 3/4 " schedule 40 PVC. If it breaks very cheap to replace. PVC cap glued to top with another hole drilled for when pole is collapsed. It works, no more broken cam locks.
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    May 2015
    Moorpark, CA
    171
    Thanks for all the ideas. Very helpful.
    Michael
