Results 1 to 7 of 7
Thread: Can Letting Chlorine Get Too Low Raise pH?
    May 2015
    Moorpark, CA
    171
    I noticed a strange phenomenon. If I neglect my chlorine level, and it gets too low, to the point of creating some algae, I have found that the pH goes sky high. Is there an inverse relationship between chlorine level and pH, perhaps indirectly through some other mechanism?
    Michael
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    30,431
    Re: Can Letting Chlorine Get Too Low Raise pH?
    I can't think of any connection whatsoever.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I think your pH rise is also a matter of neglect.
    Houston, TX
    1,104
    pH's rise by the following
    * a lot of aeration
    * excessive rain [both dilution and aeration]
    * the addition of baking soda or other alkaline based products
    * not adding any muratic acid or similar...
    So, which ones are happening to your pool?
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    May 2015
    Moorpark, CA
    171
    I can't think of any reason in particular the pH goes up so much, no rain, no alkaline products, no aeration. This pool eats acid at the rate of about a quart a week. Seems worse as we approach summer. Is that normal?
    Michael
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Michael1 View Post
    I use more than 1qt per week in my pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    What is your TA?
