Thread: Jandy Lite2 connection leaking
    May 2016
    NJ
    2
    I'm opening my pool myself for the first time. The heater is for the pool and a separate hot tub - never once used the heater or the hot tub. Opened the pool and got everything running fine, except water was bubbling out of the heater. I took off the panel and saw that there's an unattached water line with no obvious place to connect it. Anyone have an idea on where it should go, or if it's possible to just cap it off entirely? Pics below:
    Imgur: The most awesome images on the Internet
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Jandy Lite2 connection leaking
    There is suppose to be a pressure switch attached to it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    billyz's Avatar
    Mar 2016
    Western NY - Lake Erie
    18
    The piece that is hanging down in front of everything (right hand side of your second picture) is the pressure switch that is supposed to attach to where the water is coming from.
    -BillyZ
    AG, 13k, SWG Aqua Lite T5, Hayward Power Flo pump,
    Hayward Sand Filter, Jandy Lite2 Natural Gas heater,
    TF-100 test kit, Western NY (lake erie coast)
    May 2016
    NJ
    2
    Quote Originally Posted by billyz View Post
    I actually figured it out soon after I posted this, but this was correct. Thank you!
