Thread: No Power at Pump
    Jun 2014
    Sykesville, MD
    3
    No Power at Pump
    I have a Pentair Intelliflo pump. Installed it last year with absolute no problems. Just tried to start it up and the pump will not turn on. There is power at the pump connections but the green power light is not on an I can not get anything in the display. When I initially turn it on, a Power Out Failure warning briefly displayed. Nothing is displayed now. HELP !!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: No Power at Pump
    Welcome to TFP
    Is there any surge protective device for your pump, the number one problem with VS pumps is a voltage spike, brown out, lightning, also some have seen water/moisture get into the controls
    Intermatic PS3000 Pool and Spa Surge Protective Device - - Amazon.com
    this one is about the best out now
    Amazon.com: Eaton 109420 Ultra Surge Protection 3Rd Edition: Electronics
    It sounds like the control box is bad and will need to be replaced
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    I would try turning off power at the circuit breaker, and let it sit for 15 minutes then turn it back on and see what happens. If you still have the problem, I would suggest to contact Pentair.
    Quote Originally Posted by mchariko View Post
    Divin Dave,
    Jun 2014
    Sykesville, MD
    3
    No surge protector installed. NO moisture observed in the controls. Do you know of a way to bypass the controls to test the pump? Thanks.
