Thread: Need help with proper sequence to get back sparkling pool
    Jul 2015
    Houston, TX
    89
    Fellow TFPers! I've been struggling all spring to keep algae off my pool walls. Have done a couple of SLAMs which helped temporarily, but take my eyes off the ball for a bit and it's back with a vengeance. I've been a bit delinquent on my end too, but seems like I need a Grand SLAM to get it back in shape for the summer.
    Here's where the pool chemistry is at the moment:
    pH: 8.2
    FC: 0
    CYA: 20
    TA: 60
    What would be the best sequence to bring the pool back in line? I'm confused about whether to adjust pH first, or TA, or CYA before proceeding with the SLAM.
    Also, I'm planning to clean the DE filter elements and recharge with fresh DE, as well as clean behind the lamps on this SLAM to prevent a recurrence. Should I do this before or after the SLAM?
    Also, the pool walls have a light yellow / green coat. Would be safe to assume mustard algae and treat accordingly?
    Thanks!
    25,000 gal, in-ground, plastered gunite, Pentair NSF 60 DE Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,190
    Re: Need help with proper sequence to get back sparkling pool
    pH is always first. Then Add sufficient CYA to get to 30. SLAM away
    Ignore TA for now.
    Mustard is usually not all over the pool, but limited to the shady areas.
    Support the site
