Thread: Using cal-hypo?
    Feb 2015
    North Alabama
    58
    Using cal-hypo?
    I rely on my SWG for regular use, and I've always used bleach if I need to slam the pool. However, a neighbor (who recently filled in their pool) gave me about 20 1-lb bags of "shock" - cal-hypo 73% Leslie's brand. Can I use this to SLAM my pool if I have an algae problem? I would like to be able to use up what I have on hand, before buying more bleach. My current calcium level is 80. Pool Math says that one pound of this shock will raise FC by 3.5 and raise CH by 2.4.
    Is there a downside to using this instead of bleach? Would I need to turn off the SWG when I add it?
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,865
    Re: Using cal-hypo?
    The downside is adding calcium to your pool. You know your CH is only 80, so it wouldn't hurt. If you use the cal-hypo for an extended period of time, I'd keep checking CH.
    I'm on SWG as well and have successfully used cal-hypo for slam even though I usually use bleach.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Using cal-hypo?
    Yes, you can use it to SLAM. But with a SWG, your FC shouldn't ever drop low enough for that to be necessary. Good thing the stuff has a long shelf life, as long as it stays sealed.
    You can also use it to boost FC quick, like right before or after a bog swim party. Poolmath does have Cal-hypo listed in the dropdown menu for FC adjustments. Just know that once the bag is open, it will start degrading.
    Feb 2015
    North Alabama
    58
    Re: Using cal-hypo?
    Perfect, thanks for the info!
    Polaris 280
    TF-100 test kit
