Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: First time opened
    Jul 2014
    Manhawkin/ NJ
    82
    First time opened
    I'm a little confused on what I'm doing, first time opening my new pool. It's about 15000 gallon 16x32 free form. Pool looks very clean here are my numbers with the tf kit.
    Fc 15
    Cc 0
    Ch 100
    Ta 110
    Cya 50
    Anything I'm missing, pool is a chlorine pool for now, gonna be adding a hayward 40000 gallon swcg next week. How do those numbers look. I'm on my phone now will update my signature when I can get to a computer
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,599
    Re: First time opened
    Why is your FC so high compared to your CYA?
    Jul 2014
    Manhawkin/ NJ
    82
    I really have no clue what they even mean, I know I have to do some pool school reading just alot to take in.
    Jul 2014
    Manhawkin/ NJ
    82
    Is it at least safe for me to be cooling off in?
    Jun 2014
    15,096
    I'm assuming your pool is an in-ground plaster? So when you get a chance please update your signature with pool info. CH is low for a plaster pool, so watch that one. The FC will fall on its own if you allow it. As long as you have clear water and no signs of algae, just let the FC drop to about the 4-6 range. Never below 4. Good luck on your SWG!
    Yes, you can swim.
    30,419
    Yeah, your fine to cool off all afternoon.....your just wasting some FC but no harm will be done.
    As you begin your learning journey with us, I hope you will read "The ABC's of Pool Water Chemistry" up in Pool School. It's our reference to everything we suggest on the forum.
    Jul 2014
    Manhawkin/ NJ
    82
    Yes defiently gotta do some reading just been so busy getting yard done, pool is vinyl liner. I think we did have algae when it opened the pool guy shocked it and then a couple days later it looked like dirt in bottom that I vacuumed up and hasn't come back, I do notice that there is alot of real fine things floating on surface but I'm assuming it's just pollen, pollen is real bad here right now. Thanks allot for all the help and future help.
    Jul 2014
    Manhawkin/ NJ
    82
    Is there any thing I need to add or anything I need to do to get my numbers more in line
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Noticed you didn't post a pH number as well. That is an important number you want to get right off the bat!
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jul 2014
    Manhawkin/ NJ
    82
    Looks like a 5 on the cl yellow and and ph of 7.5
    Jezza's Avatar
    Jan 2015
    880
    How clear does the water look? If your pool guy has done the shock and run treatment for the algae it is likely that it may not be totally eradicated. Are you familiar with the SLAM process we advocate here?
    K-2006
    Jul 2014
    Manhawkin/ NJ
    82
    Water is very clear I went out and scooped up what I thought was the dead algae on the bottom and it was all pollen bunched together, could I possibly have algae though?
    Jezza's Avatar
    Jan 2015
    880
    I thought that you mentioned you might have had it above or are you not sure?
    K-2006
    Jul 2014
    Manhawkin/ NJ
    82
    I was not sure sorry, I thought what looked like dirt at the bottom of the pool could have been dead algae, I scooped some last night and it was pollen, should I be adding anything or let it be until the Fc gets into a good range
    Jezza's Avatar
    Jan 2015
    880
    Generally the first sign that you have algae is a high demand on your FC where you battle to hold a normal level of FC, then the pool water starts to look cloudy before it starts to take over the pool and turn green.
    You could do what is called the OCLT, where you test your FC when the sun goes down and then get up early just before the sun comes up and retest your FC. This excludes the effect of UV sunlight on your FC level. If your FC loss is greater than 1.0 then you need to SLAM because you have an abnormal amount of organics consuming your chlorine which need to be dealt with sustained shock levels of chlorine.
    K-2006
    Jul 2014
    Manhawkin/ NJ
    82
    OK thanks I will try and get to that tonight, other wise I should just let it be all day?
    Jezza's Avatar
    Jan 2015
    880
    Yep your FC was high to start with so just let it be then perform the OCLT tonight.
    K-2006
    Jul 2014
    Manhawkin/ NJ
    82
    Today
    Ph 7.5
    Cl 5
    Fc 10
    Cc 0
    Cya 70
    O yeah speed stir made it allot easier
    Jul 2014
    Manhawkin/ NJ
    82
    Just took my Fc number with no more sun on the pool, I'm at 5.5. I droped from 10 this morning. I'm gonna check it first thing in the morning to make sure it doesn't drop by more then 1. Is dropping 4.5 allot for a pool in full sun all day?
  20. Back To Top    #20
    Jul 2014
    Manhawkin/ NJ
    82
    Should I turn the filter off for the night to test for algae or is it fine on?
