Thread: No water coming out.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    I am at work busy as heck and my wife calls ands says she can't feel any water coming out of the returns. Pump is running and pressure is around 18. Skimmers are clear. What do I tell her. Turn off pump? This is our 3rd day enjoying our new pool.
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: No water coming out.
    Perhaps the valve is turned so all the return is going to the spa?
    What's normal pressure? It's possible the filter is clogged from plaster dust.
    When in doubt, shut off the pump and "Wait until your father gets home!"
    30,432
    I would shut it off. It can be a hundred things and that's just not enough info to troubleshoot.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    That's what I told them. Pressure sits between 12-18.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Water is going somewhere or the pressure would be higher than that. Other returns?
