Results 1 to 9 of 9
Thread: Opening the AGP and adding Borax
    May 2015
    Walden, NY
    10
    Lightbulb Opening the AGP and adding Borax
    Hello every one!
    I intent to open my pool today (NY) and i like to add Borax (50ppm) to my 14.500 gallon AG pool. I know what to do and how to used both products, borax and muriatic acid to keep the PH at normal levels. I learned all here, thanks to you guys. The only question that i have is: What to do first, meaning the right steps; shock it first/ raised the alk? Than borax? or do the borax first than take care of the chlorine afterwards? Here's my readings:
    FC 0.08
    TC 019
    PH 7.2
    TA88
    CYA 40.
    The water is clear, cover still on it, water back to normal level ( 1/2 way on the skimmer).
    Thanks!
    18'X33'X52" Aqua Leader. Hayward Perflex EC50 Filter System With 1.5 HP Pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Opening the AGP and adding Borax
    Always maintain chlorine first and foremost or the pool will be unsanitary and algae will grow. Chlorine needs to be above minimum for CYA at all times, Chlorine CYA Chart
    I would lower TA to 60 before adding borates, Pool School - Lower Total Alkalinity
    May 2015
    Walden, NY
    10
    Thanks! To shock the pool, should i use the liquid Clorox 8.25%? Or use the powder package that I have left from las season? i don't have to use it, if you think will mess up the water going to the BBB method and adding the 50ppm borax. Thanks again!
    May 2015
    Walden, NY
    10
    Prior to add Borax: I think I lowered the AL too much (40ppm) from 90. Here is how I did it: After chlorinated the pool to 6 ppm FC, brushed and vacuumed the pool to waste, tested the water last evening, FC 6.0 PH 7.5, TA 90, CYA 40, TH 230. Pump ran all night. Shut it off wait a our, dumped a 1 gl and a 1qrt of muriatic acid, premixed it on a 5 gl pail first. wait 1 hour and tested the water. Results: FC 3.5, CC 4.4, PH 6.5 TA 40,TH 120 CYA 40. Now what? Please help!! Should I add half of the borax since the PH is low? about the TA? Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by aprendiz View Post
    Yes, deal with the pH using Borax. You already have it there waiting! Then resume your routine. TA will rise a little bit with Borax, but if it isn't enough, deal with it after. That's like the easiest thing to fix and less important than pH and FC by leaps and bounds.
    May 2015
    Walden, NY
    10
    I though about the PH been low, but wasn't sure how much the borax will raise it. Whiling waiting for your response, i did dump 9 boxes of it (689oz) if my math still working properly. I add 1/2 gal of acid to in case. Keep the pump running? or stop it until I add the rest of the borax? And how long should I wait to test the PH, etc? Thanks Richard, great appreciated!
    Richard320's Avatar
    Jan 2010
    18,967
    Just plug numbers into poolmath and let it calculate the borax dose to get pH up to your target.
    Pump running anytime you add chemicals. You want that stuff mixed as fast as possible, nothing pooling up or settling out on the floor.
    May 2015
    Walden, NY
    10
    I got now. I had the 50 ppm borax goal in my head, 824 oz according to my water volume (14.500gl). How long should i wait to test the water, than add the rest of the borax, 288 oz according to the poolmath to bring the PH to 7.4. Thanks!
    Richard320's Avatar
    Jan 2010
    18,967
    Wait half an hour or so, and brush some to make sure all the water is well mixed.
    The rest of the borax addition is out of my league. I never added any borates to my pool.
