Thread: Landscaping rock bed help!
    May 2016
    newburgh,in
    7
    I've got 18ft coleman with level sand base and tarp over top sand. I've had 3 poles settle and sink a fractional amount. I am wanting to put landscaping edging around base of pool for rock edge border. Before I start digging small trench for rocks, should I be worried about making those poles sink more? If so, what can I do? Trying to post a picture.20160528_090630.jpg
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Landscaping rock bed help!
    Welcome to TFP
    under every one of the legs should be a cement footer 12x12 at least 2 inches thick, the pool legs can settle and collapse the side of the pool if too far out of level
    Shop Gray Square Concrete Patio Stone (Common: 12-in x 12-in; Actual: 11.7-in x 11.7-in) at Lowes.com
    May 2016
    newburgh,in
    7
    Can I add those while the water is in it or would I have to drain the water?
    Jul 2013
    Fletcher, OK
    3,353
    your pool has about 6700 gallons and weighs in at 63,000 pounds or about 27 tons
    unless you have a big green guy on steroids you will have to empty it to about 6 inches or so..
