Advice leak at pvc joint
Aug 4, 2015
84
Boston, MA
Hey all,
So probably need to get a plumber for this but have a question. My pool pvc pipe joint starting squirting water this morning right from under the joint in one spot. May have a crack in the flexible piping not sure. Cant see how to attach a pic here as well its squirting out at the joint and squirting down towards the ground. Its like white grooved pipe coming out of the ground going into an elbow joint. How do I get the water out of that pipe though is my concern if a plumber comes? I closed off all the valves this morning.
