Thread: glow sticks
    Aug 2008
    Las Vegas, NV
    116
    glow sticks
    Is there any reason that I could not throw a bunch of glow sticks in the pool at night for a cool effect? (as long as none are leaking?)
    Pam
    Re: glow sticks
    Don't see why not... sounds cool!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: glow sticks
    They're sealed so that the stuff inside can't leak out, and they're plastic, and will likely float, so there shouldn't be any problem with them in the pool. They will likely end up in the skimmer or the kids will start tossing them around and they'll end up over the fence.
    The big question is how many glow sticks will it take to light up a pool? And don't do that Owl and Tootsie Roll thing and just say "3".
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Re: glow sticks
    Don't forget the photos
    Happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Aug 2008
    Southwest New Hampshire
    52
    Re: glow sticks
    Here's a detailed report on Chemiluminescent Glow Sticks. They seem pretty harmless.
    http://archpedi.ama-assn.org/cgi/reprint/156/9/901.pdf
    We put a bunch of rings in last year. Kids had a blast.
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: glow sticks
    Be careful with the skinny cheap ones found at dollar stores, etc., they break easily. I don't know what's in them if it's toxic or not.
