Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: SLAM process two weeks and cloudy?
    May 2016
    Texas
    21
    All. I think I have been patient but need to know if I am missing something although we have had really humid days and had several rain storms just as I started this process. I am using Taylor K-2006 test kit twice a day and have been keeping FC level above 12, sometimes up to 14 or 16 (since my CYA seems to be about 30 )using HEB bravo liquid bleach vacuumed twice, brushing, back washing about once every two to three days. Water looks much better but is still cloudy. I can take my net and run it through the water. There are some tiny what I believe to be oak blossoms. They are clear from the bleach but not completely gone. I plan to get some type of filter socks today.
    Just wondering if I am missing something. Thanks
    Bill
    13000 AG (above ground) 24 ft round
    Carefree High Rate Sand Filter 19 inch, 150 lb capacity
    Waterway Hi-Flo Two Speed Pump Model No SD-10-2N11MB
    June 2014 / Taylor K-2006 / City Water
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SLAM process two weeks and cloudy?
    Welcome to TFP
    You are doing great, keep it up..
    You don't need to backwash untill your pressure raises 25%, your sand filter will work better as it gets dirty
    post up all your numbers to see what your levels are
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Hi, Bill.
    Two weeks is too long. Sand filters are slowest about cleaning the cloudiness, but not that slow.
    Sounds to me like maybe the filter is channeled. The sand hardens up over time with Calcium and stuff it's filtered out. Then you backwash and disturb it and it breaks up into clods and doesn't settle back into position, leaving big gaps -- channels through the sand. Nothing gets filtered. The solution is Deep Cleaning a Sand Filter
    After that is done, you might even try to Pool School - Add DE to a Sand Filter. That will be like putting window screen above chicken wire, just on a microscopic scale, inside your filter. It'll get that cloudiness out. Don't skip the cleaning first, though; if there are channels, DE will pass through and make an even bigger mess of things.
    Skimmer socks are a great idea. People have been using hairnets lately, but I still have some knee-high nylons I bought a while ago. Either one is cheaper than the filter socks sold in the pool section.
    May 2016
    Texas
    21
    I will follow suggestions (clean filter, add DE, run complete tests) and post up results. BTW, what numbers do you need? I thought numbers would be off due to elevated chlorine levels? Thanks for lightning fast responses.
    Bill
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by moondogtn View Post
    Bill
    You are correct. pH will be totally wrong at shock level FC. Casey just wants to confirm you're keeping FC high enough for your CYA level.
    May 2016
    Texas
    21
    I was able to clean the sand filter today and then got called in to work. I tested FC which was 10 before leaving and added 121 oz of 8.25 bleach.
    While I was out, had a pool full of people, which probably didn't help. I tested FC once they were out and it was 10.5, added 121 oz of 8.25 and ran to store for more bleach.
    I then ran all tests, except pH.
    FC=15
    CC=.5
    pH=not done but can if requested
    TA or Calcium Carbonate=150
    CYA is approximately 30 although I can still just make out the dot when vial is full
    CH=175
    I will try to get around to some of the other steps tomorrow. Thanks again for assistance.
    Bill
    Jul 2013
    Fletcher, OK
    3,353
    Bill
    Sorry about that, I should have just said FC, CC just to make sure where you were at...
    From your new tests tonight youre looking good, how does the water look
    May 2016
    Texas
    21
    It seems better but not clear. I will take pics tomorrow. You can see your feet on bottom but not clearly. I still find a few leaves when using the net but you can't see them through the water if that makes sense.
    May 2016
    Texas
    21
    Okay, I was on call and had to go out several times this weekend. I also want to add that it rained which adds leaves and rain water as well as company over that went swimming so...I knew it would be harder to do this but I am trying to stay on top of it.
    First link is photo from May 28th
    May282016 Photo by moondogtn | Photobucket
    Second is from this morning May 30th
    May302016 Photo by moondogtn | Photobucket
    I did toss about 16 oz of granulated dichlor in there to try to add some lasting effect since the liquid was not seeming to last with all of this activity.
    Measured FC last night to be 17, this morning after the rain(leaves) and more swimming last night it was 13.5, No CC this moring.
    It looks better but after today swimming will be limited so I hope it will be easier to get this finished. I still plan to pick up the DE if I can find it locally.
    See whay you folks think.
    Bill
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    With a SLAM you have to test and adjust the FC more than twice a day (but not more than every hour) everyday. If you skipped a whole day that put your SLAM back a good bit.
    Also, I would stick to bleach unless you purposefully want to raise your CYA
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    As previously noted, the sand filter does take the longest to clear cloudy water. I'm pretty sure I was at it for about two weeks as well. If you do add DE, brush brush brush. When I did this my pressure started rising a lot more rapidly, telling me it was working.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2016
    Texas
    21
    I agree but it is pretty tough to do when I haven't been here. Typically, on call is no big deal but this weekend has been a bit nuts. Also, the CYA level was about 30 maybe lower during initial tests and since they really don't give you enough reagent to test it more than a couple of times, I have no more. I ordered a pint but USPS left a notice that it was leaking and damaged. That was Friday so no chance to follow up there. It would have probably been beneficial to know that I needed gallon jugs of the specific reagents prior to beginning SLAM process. However, I will continue to use what I have and hope for the best. Is there any other semi-reliable(i.e. Good enough to get through SLAM) CYA test method?
    BTW, the second pic doesn't look as good as it should. You can actually see the leaves in the bottom and the screw on those steps clearly. Thanks for the input and I will post up results later if I don't get called out again.
    Bill
    May 2016
    Texas
    21
    Good news, no work today so I was able to monitor it more closely.
    10:00 FC 13.5
    11:30 FC 14.
    People swimming
    2:00 FC @ 12ppm
    Added 121 oz bleach
    6:00 FC 13.5
    8:00 FC 13.5
    Will test again tomorrow morning and hopefully it will level off and be clear.
    Bill
    May 2016
    Freehold, NJ
    3
    Quote Originally Posted by Mr Bruce View Post
    You can use cleaning bleach instead of the packages of shock? Do you dilute it first?
    21,600 gallon IG Vinyl Grecian Pool 16x32 with a sand filter, Hayward AQR 15 AquaRite Salt Chlorine Generator(new), Hayward SP2610X15 Super Pump 1.5-HP Max-Rated Single-Speed Pool Pump(new), regular water source, TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD
    Howell, NJ
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by NateEssex View Post
    Regular bleach, yes. Concentrated is okay. Splashless, scented, or any other "special" can NOT be used. If you pour it slowly in front of a return you don't need to dilute it. Be sure your pump is running, of course.
    May 2016
    Texas
    21
    The bleach I am using is the 8.25% concentrated HEB Bravo.
    Checked it this morning
    FC 13.5 so no loss overnight.
    I will be gone all day, should I add bleach before leaving?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Not if your CYA is still 30. How does the water look?
    Jun 2014
    15,103
    Bill, I'm like you. I use primarily the Bravo stuff. It will work just fine. Based on your schedule, it's looks like you're doing the best you can. We understand, as do you, that with absence comes a slightly longer process. But even with your time away there IS progress. The pics prove it. So hang in there. Once you receive your replacement CYA reagents, test it again to ensure you're at the correct SLAM level. No overnight loss is great. Your current FC of 13.5 should be fine for today since you passed an OCLT and have next to no CCs. Clear water is a requirement for passing the SLAM, but you stated you can see quite well. The additional clarity might just be a matter of time with that filter now that you deep cleaned it. The DE might help as well. Your call though. Have a good day.
    May 2016
    Texas
    21
    Thank you both for the advice. I plan to check with usps today and see if they actually have the package containing reagent and how badly it was damaged. If not, I'll need to order more.
    Water is looking better although slow to clear up. I am awaiting the crystal clear water. Perhaps I will hold off on the DE for a bit and see how it looks. I'll try to get another pic this afternoon if there is any noticeable difference. Thanks again.
  20. Back To Top    #20
    May 2016
    Texas
    21
    Tested at noon, still 13.5.
