Results 1 to 10 of 10
Thread: Changing sand
    May 2009
    Trenton NJ
    497
    Changing sand
    How do most people get rid of their used sand when they replace with new?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Changing sand
    We generally do not recomend changing sand unless you have used a chemical that has gummed up the sand or calcium scale has turned it to concrete. The sand does not wear out. Pool $tores recomend changing it because they sell sand. Just clean it.
    Deep Cleaning a Sand Filter
    Support the site
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Re: Changing sand
    I agree with Tim, but if you must remove the sand best way is to drain all the water out and let the sand dry completely then vacuum out with a shop vac.
    21'x52 AGP 11200 Gal
    TFPC Method
    May 2009
    Trenton NJ
    497
    Re: Changing sand
    Ok thanks......I might have an issue with my laterals so I'm prob gonna have to remove sand. Getting some sand in pool
    May 2014
    Portage, Indiana
    127
    Re: Changing sand
    Quote Originally Posted by ethany View Post
    No fun! But if it has been a few years since you've changed sand you COULD change it since it's already out. Although fine particles in the sand could get into the pool during the first couple cycles. Plus they say dirty sand filters better than new sand. Good luck hope it's nothing major.
    TFPC Method
    May 2009
    Trenton NJ
    497
    Re: Changing sand
    Well I unscrewed the drain plug n it's taking forever for the water to drain. It's a fast trickle.....does that mean it's REALLY dirty?
    May 2014
    Portage, Indiana
    127
    Re: Changing sand
    I don't think so. I think it's meant to be more for winterization where you leave it off the whole winter. It will probably take a while to drain that way. If you think it's that dirty maybe backwash it first
    TFPC Method
    May 2014
    Franklin, NC
    9,184
    Re: Changing sand
    Have you closed all valves and turned the multiport valve to off? If not, you could be draining the pool through the filter.
    Support the site
    May 2009
    Trenton NJ
    497
    Re: Changing sand
    I disconnected all the plumbing n took multi port off the filter. Is that right? I hope
    May 2014
    Portage, Indiana
    127
    Re: Changing sand
    If there's no plumbing connected to the filter, then yes you're fine just a waiting game unless you want to try to suck out the wet sand. Just make sure when you disconnected the plumbing that either valves are closed or sealed well so the pool water won't leak out that way.
    TFPC Method
