Thread: liquid cholrine vs granular
    bobby g's Avatar
    May 2015
    southern, ct
    21
    Hi Everyone, I have been struggling with the cya / chlorine chart, there wasn't any cya yesterday when I tested. I added some granular stabilizer also trichlor granular shock, my readings this morning cya 30, fc 2 and cc 5. I have a swg which I turned down to 30% should I shut this off while I am in the shocking process also should I be using liquid shock?
    Thank You, Bobby G
    15000 GALLON POOL/ VINYL LINER
    SWG/ T-3 HAYWARD TURRBO CELL
    PENTAIR CC200 CARTRIDGE FILTER SYSTEM
    HAYWARD SUPER PUMP 3/4 HP
    RAYPAK HEATER
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: liquid cholrine vs granular
    If you are following our SLAM process than yes, turn off the SWG and use liquid only. Stop adding CYA until the SLAM is complete.
    Support the site
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Yes, it will save wear and tear on your swg if you turn it off during the SLAM process, and use liquid chlorine until the process is complete. The trichlor you added also contains CYA, so you need to be careful not to use too much. How much CYA did you add and how much stabilizer did you add? Did you broadcast the CYA into the pool or are you letting it dissolve in a sock?
    Love TFP? Become a
    TFP Supporter!
    bobby g's Avatar
    May 2015
    southern, ct
    21
    I added 4" round sock into sock and let it dissolve into skimmer IMG_2025.jpg.
    Thank You
    RAYPAK HEATER
