Thread: Does aeration impact CYA as well as pH?
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    435
    Made an aerator based on examples in old posts here. Finally seeing some pH increase! Have added soda ash and borax with no change in pH, just alkalinity. So aeration does work. I did detect a small loss in CYA at the same time. I am assuming this is merely variation due to the test method but thought i would ask the forum. i have been getting 50 ppm CYA for several days before the 40 ppm today. And yes, i know i dont normally need to measure it that often, still in newbie mode to TFP method. Thanks
    The other reason i ask is because information i received from various pool stores (i know, i know, if i heard it in a pool store it MUST be true. ha ha) trying to talk me into using tabs of trichlor that also contain cya say not to worry about increasing cya because cya is lost by people activity in the pool. hence my thought on aeration effect.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Does aeration impact CYA as well as pH?
    No, they are lying or are misinformed. You decide.
    Stay away from tabs if CYA is an issue.
    Support the site
