Results 1 to 9 of 9
Thread: New Pool
    May 2016
    Brooks, GA
    11
    New Pool
    I am in the process of filling my 27' above ground pool and I have two questions.
    1. The pool pump is a Waterway Hi-Flo II 48-Frame Side Discharge and it came with a 3' NEMA cord attached. I would like to install a pool timer for the pump however the timer I purchased (Intermatic T104R 208-277 Volt) needs to be hard wired to the pump. Should I just remove the cord and hard wire it myself or what other options are there?
    2. The pump is 115 volt / 13.5 amp. What size circuit breaker should I use in the breaker box? I am going to hard wire the pump/timer as a dedicated circuit. Also, with the aforementioned specs will the pool timer from question one work or should I exchange it.
    Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New Pool
    Technically removing the plug causes the pump to loose it's UL listing. Many people don't care, but insurance companies do. I wouldn't cut it off/ remove it. Just add a new receptacle that is energized by the new timer and plug it in there.
    The size breaker is determined by the size wire and down stream devices installed. Is this all new wiring? If so go with 12g minimum on the wire and 20a GFCI breaker.
    What is the depth of the pool as that is the determining factor on the electrical regulations that need to be followed?
    Support the site
    May 2016
    Brooks, GA
    11
    Re: New Pool
    tim5505,
    Thanks for the prompt response. I was thinking about installing a switch between the pump plug-in and the timer. The pool is 54'' tall so therefore its a permanent pool. Its all going to be new wiring from my outside breaker box under my power meter. I feel comfortable doing electrical in-side a home but this is the first time I have had a pool since I was a kid and then my parents handled all of this stuff.
    30,414
    Re: New Pool
    Hi, Bill, Welcome to the forum.
    Is that pump capable of running 220v? Generally, that works a bit better for pool pumps.
    May 2014
    Franklin, NC
    9,184
    Re: New Pool
    Quote Originally Posted by billtrivett View Post
    tim5505,
    Then you need to follow the full pool code including a bonding grid around the pool and attached to all equipment.
    2014 NEC from Mike Holt : http://www.mikeholt.com/download.php...as_2014NEC.pdf
    Support the site
    May 2015
    Walden, NY
    10
    Re: New Pool
    Total agree. Also, the motor last longer and more cost efficiency.
    18'X33'X52" Aqua Leader. Hayward Perflex EC50 Filter System With 1.5 HP Pump.
    May 2016
    Brooks, GA
    11
    Re: New Pool
    Thanks everyone for the quick replies. I talked to an electrician and will get the 120 volt timer with a 20 amp breaker.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: New Pool
    You still should have a switch that is visible to shut it off in emergency.
    May 2014
    Franklin, NC
    9,184
    Re: New Pool
    Quote Originally Posted by banditig View Post
    correct, it needs a shut off within sight of the pump. If the breaker is nin a sub panel of 6 breakers or less it can act as the switch, again it has to be within sight of the pump.
    Support the site
