Thread: Pool heater
    Jan 2016
    Richmond Hill
    1
    Pool heater
    Can I use a 20 pound propane tank for a raypack 105,000 btu . The installation book says caution do not use 5,10,20 gallon propane tank why?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool heater
    Welcome to TFP
    I will not have the volume needed to supply the amount of gas to your heater and it would probably be empty in about 5 minutes... the smallest I have seen on this site was a 300 gallon, I am sure someone has used smaller but I am not sure...
    the manual says to use 1/2 steel pipe for connection with manual shutoff valve
    http://cdn.globalimageserver.com/fet...2-87c3095e4395
