Thread: Solar Cover / low chlorine
    Sep 2014
    Fort Wayne
    1
    We recently put a solar cover on our inground pool, we've had to add bleach more often than prior to the cover, is this normal?
    My pool is 36 x 21 and it's the Deer Creek style (similar to kidney). It's an in-ground pool that we put in ourselves as a kit. It has a vinyl liner and we use Hayward equipment.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Solar Cover / low chlorine
    Welcome to TFP!
    That is opposite of normal. Usually a pool cover will lower FC consumption because of reduced exposure to the sun. I put one on a couple of weeks ago for the first time and my FC went up with my SWG on the same setting.
    Unless your water temp went up and you are taking the cover off during the day.
    Please add your state to your location, climate is important when we help you with your pool.
