Thread: Removing O ring from Hayward Tristar pump lid
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Is an O ring removal tool or pick recommended to get the O ring out of the cover of strainer basket on Tristar pump? I don't want to destroy it by using a screw driver. It may still be good. Does anyone know of something around the house I could use to get up under it?
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,989
    Re: Removing O ring from Hayward Tristar pump lid
    Quote Originally Posted by ned8377 View Post
    How about a table knife or a cheese spreader? They're usually thin and dull. Slide around both sides to loosen any hardened grease before you try lifting it.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Thanks Richard. I found a cheap tool at Auto Zone but think I will try the knives first.
