Thread: Add Air to Spa Return
    Hi there,
    I currently have an air bar in my inground jaccuzi. Works great, no issues... except the bubbles are really loud while you are in the jaccuzi and during the winter time the bubbles are REALLY COLD....
    How difficult is it to add bubbles to the return jets in the jaccuzi? Is it as simple as plumbing the blower directly into the return after the filter?
    I'm thinking of adding a valve at the blower to either divert air to the air bar or to add air to the return air water.
    Now if I do plumb it into the return air jets.. will that add nice small bubbles that most jaccuzi's have or will I have plop plop plop like when the filter is started up after being cleaned?
    Thoughts?
    Thanks!
    Jeremy
    13,750 gal Fiberglass
    Sta-Rite System 3 Sand Filter
    FC - 8
    pH - 7.7
    TA - 80
    CH - 140
    CYA - 60
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Add Air to Spa Return
    You can't add air without using venturi tees and if they were not installed originally, it would be very difficult to do now.
    Mark
