Thread: Help !!! pool pump
    May 2016
    Bridge City
    1
    Help !!! pool pump
    I have a saltwater pool i took the salt cell off ti clean it and put everything is installed correctly start my pump back up and it started surging and make a noise like it was struggling my pump stays primed so i disconnected the discharge and it ran fine put sounded good running smooth when i put salt cell back it there it goes again back to surging or pulsating like it has a restriction on the return I DON'T KNOW ! I tild the wife lets fill it in with concrete and build a basketball court "not really" please someone help or advice
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Help !!! pool pump
    iWelcome to TFP
    Does it look like this
    CircuPool® T-15 Replacement Cell
    if so, try turning it around... if not can you post a picture of your setup
    Jun 2015
    Charlotte, NC.
    82
    Sounds like a blockage in the cell or a backwards check valve. Try pouring water through the cell in the direction of flow and see what happens
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    30,421
    Is there enough water in your pool? The surging sounds like your water is too low and it is sucking in air at the skimmer. Filling your pool up a little higher will stop that.
