Thread: New home and pool, and left over gaskets / parts when de-winterizing?
    May 2016
    salt lake city / Utah
    6
    Hi, I am new to the forum and plan to be an active user. Appreciate the help in advance.
    I purchased the home last year (first pool), and had a company come and winterize it (I am in Utah, so cold winters). They disconnected quite a few things (plugs in heater and line to filter, pump, etc) and when I go to put the pieces back together, there are several parts that I can't find a home for. The companies are insanely busy right now, and are weeks out. I'd like to get it started up on my own if I can. It looks like the pump was disconnected from the filter, and then the basket was disconnected from the main lines (apologize if my terminology is off). I dont see any other pipes disconnected. They did plug the filter basket off the pool (assuming so that they could drain water out of the piping). A few pictures of what I have.
    The first shows the leftover pieces I have, the second and third show the pump assembly going to/from the filter/heater and pool. Any Ideas what they could go to? Or any thoughts/suggestions on what I should do as I reconnect the equipment?
    Jun 2012
    western NY
    1,562
    Re: New home and pool, and left over gaskets / parts when de-winterizing?
    The first one looks like a washer that may have come from an old expandable winterizing plug. The second one may be the gasket that goes in the union that is disconnected. The third one I am not sure. The fourth one is a leftover jamb nut for a Romex clamp. The last one is some sort of thread in cap to close off a pipe
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by danpik View Post
    The third looks like an insulated bushing that fits inside electrical conduit ends.
    Jun 2012
    western NY
    1,562
    ^^^^^^I was on my phone when I posted that. Back on a computer and can see it better now. Yes, bushing
    May 2016
    6
    Thanks so much for the quick help! After looking up what you guys had suggested, I think you are right. I didn't realize what went into winterizing the pool, and after doing some reading it makes sense. I'm sure i'll be back, haha..
