Thread: Rainwater Tank
    Chatabox's Avatar
    Apr 2016
    Queensland, Australia
    64
    Rainwater Tank
    Question for you more knowledgable pool experts....
    We have 2 (soon to be 3) rainwater tanks on our property. We use a pump and fill the spa every 3 months from the accumulated rainwater. My question is, should we be doing anything with the rainwater while its sitting in the tank?
    My partner suggested throwing some bleach in there to stop any potential algae, as the inside of the tank doesn't look the loveliest. But I don't really want to have to keep up a maintenance schedule for a rainwater tank.
    5900 litre or 1558 gal above ground swim spa. Approx 5 years old and heated to 37 degrees celsius year round. Cartridge filter, ozonator, Nature2 mineral sanitiser, Aqua Health non chlorine based shock, Lithium Hypochlorite dosed at each spa usage. Filled using mostly stored rainwater from tanks, and town water when the tanks are drained.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Rainwater Tank
    Are the tanks opaque? If they are then no worries.
    Chatabox's Avatar
    Apr 2016
    64
    Re: Rainwater Tank
    Yeah, they're a tan coloured though. So they let light through. Just not direct sunlight. There is a mesh area at the top that the drains pour into, and that's open to small amounts of sunlight.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Rainwater Tank
    Is the outlet at the very bottom, or is there room below for sediment to collect?
    If there's a couple inches below the outlet, just give the tank a blast of bleach a day or two before you empty it. Any algae will get killed and settle out.
    Chatabox's Avatar
    Apr 2016
    64
    Re: Rainwater Tank
    Here's one of the tanks. There's a little bit of space underneath it.
