Thread: Pool opening surprise--is this a new kind of red algae?
    West Chester, PA
    53
    Been opening my pool for years with knowledge from this site, so green slime or water doesn't phase me.
    But what in the heck is this? Do I just continue with my normal pool opening procedure? It continues around the water edge along with the normal green algae...
    TF-100 Test Kit, 28,000 gallon IG , 3M quartz plaster '09, 48 sq ft DE filter, Heat Siphon SX5HP heat pump '09, Polaris 360 '10, Protect-A-Child safety fence
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Pool opening surprise--is this a new kind of red algae?
    Can you scoop it up and feel it? It looks like it might be dust off the coping.
    West Chester, PA
    53
    No, it's definitely growing. It's all around the scum line of the pool also. Bricks are not new, although the stuff is brick colored.
    I just need to know if I should use a higher SLAM number if it's some sort of weird algae.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I used to get red algae in my saltwater reef tanks sometimes. I would start with a regular SLAM. If you pass the 3 criteria amd it is still present then try mustard shock 24 hour treatment.
    West Chester, PA
    53
    Ok, in process of SLAMing. Balanced pH to 7.2, then Alkalinity to 110. Brought chlorine to 14 just in case it's a harder to kill algae than green. Have backwashed twice. Brushed twice. Chlorine dropped to 13 in 3 hours.
    Aaaand, the red scum is now turned black. Fading, but really hard to scrub off of the waterline.
    Do I treat it as black algae now that it has changed from brick red to black? Green water changing to blue.
