Thread: Small, above ground pool convert to salt water?
    Apr 2016
    Florida
    29
    My small 10'x30" Intex Steel framed pool was recently filled and started up about 2 weeks ago. I finally have gotten the hang of the chemicals but now my daughter is in the process of an official diagnosis of the skin disease Vitiligo that is said to worsen by pools chlorinated with bleach.
    Would anyone like to shed some light and tips on how to 1. if it's possible to convert it and 2. how to?
    Thank you kindly!!
    Donldson's Avatar
    NW Ohio
    2,914
    Re: Small, above ground pool convert to salt water?
    Has she been using the pool without problems? If so then there is no reason to change anything. Also, TFP pools are considerably less harsh than most other chlorine managed pools, many people that don't do well in other pools seem to have far less problems in a TFP pool.
    Finally, salt pools are great if you want to get an SWG, but they are still chlorine pools. If someone has issues with a TFP pool chlorinated with bleach then they will have the same issues with a TFP pool chlorinated with an SWG. If she is having problems with the pool and you are managing it within TFP parameters then you might have to look in to something like Baquacil. I would expend all of your chlorine options first before considering that, but in cases of true chlorine sensitivity it is an option.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2016
    Florida
    29
    Thank you for your response and advice! I did not realize that both types of pools were that equal.
    I appologize but please elaborate, TFP vs other chlorine managed pools? Is it by using the TFP calculator and specific solicited advice? I have been thankful for the help here and value it more if it helps with my daughter's condition.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Conversion to SWG on an intex is probably the easiest one there is. Dump the required amount of salt into the pool, unscrew a fitting and insert the SWG between the two ends. Plug it in and turn it on. Hardest part is carrying the salt in from the car.
    A saltwater pool is a chlorine pool. Instead of chlorine bleach being created at a huge plant somewhere and then bottled and shipped, it's created onsite in the SWG using exactly the same process on a much smaller scale.
    You may find that a certain pH is more irritating than another and you can control that yourself. And if you use our methods, you won't have that smelly irritating chlorine smell you associate with public pools and water parks.
    Donldson's Avatar
    NW Ohio
    2,914
    Mostly by TFP pool I mean running your pool by using the FC/CYA ratio chart to determine your chlorine level and avoiding unnecessary chemicals in the pool that could potentially have negative effects on comfort. Some algaecides for instance use ammonia which will increase the CC level with can be relatively unpleasant even if you don't have increased sensitivity. By following the FC/CYA chart you run a relatively low active chlorine level (CYA heavily buffers chlorine strength) but also keeping enough chlorine to oxidize the irritating CC and keep algae at bay without using other chemicals. Just as an example, I have been asked if I have a chlorine-free pool before even though my FC level is typically near 6.
