Results 1 to 7 of 7
Thread: Interest in Hayward Pool Heater
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Just out of curiosity is anybody using the Hayward H100ID1 Nat Gas model? If so could you please post thoughts, good, bad or indifferent.
    Thanks in advance!
    R
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Jun 2012
    western NY
    1,562
    Re: Interest in Hayward Pool Heater
    I have one. Have had it connected for about ten years now. The heaters built during the time I bought mine had board problems. Not sure if that problem has been fixed. Other than that, all other problems have been self inflicted.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Thank you Danpik,
    It sounds like you have had really good luck with yours. I was eyeing up the RayPak 105,000 but buying it through a plumbing store with their markup + install pushed them out of the running. I spoke Hayward and they said as long as licensed gas fitter/plumber installed warranty would be honored, so I could buy online and save a bit.
    My solar works great when the sun shines but alas I live on the "wet" coast and we could go days without sun. I'm basically just looking for something to work with the solar.
    Cheers,
    R
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    That is an old Hayward model. The newer Hayward is a FD unit. Go with Raypak. For the extra money get a 266K unit. Should only be a difference of a few hundred. Well worth it.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2012
    western NY
    1,562
    I will agree with Paul on this one. Most of the luck I have had with mine is that I service home heating systems and some pool heaters. My experience with these things is mostly what is keeping mine going after all these years. Since my first post in this thread I opened my pool and found a problem with the heater. When I turned it on the blower fan sounded like a bike wheel when we were kids and put playing cards in the spokes. Without even opening it up I knew exactly what it was. I will be posting pictures and the repair process later this week. By the way, the fan,motor,housing assembly for this unit runs around $300.00.
    Dan
    Dec 2014
    Riverside California
    482
    Raypak (Rheem) seems to be the heater of choice from what I have read on this forum. I had a Rapak heater last 22 years before I replaced it with another Raypak last May.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Thanks guys,
    Setting up the gas install tomorrow. Its a 6 week wait list. It will give me time to organize...
    Cheers,
    R
