More rains for Houston, Montgomery, Fort Bend and others. Brenham w 23" of rain
tstex
2,189
Houston, TX
Hello to All,
OK, my CA has been diluted, my CYA has been diluted, my FC has been diluted and so has everything else. But, rain water is tops. So, all this rain [this time] is done, I will post my results and see what things I need to do to keep all well w my CSI as too.
Best to all,
tstex
Re: More rains for Houston, Montgomery, Fort Bend and others. Brenham w 23" of rain
it's crazzy isn't it, I have had to drain over 6 inches out just to keep it at the top of the skimmer..
we'll my pH prior to rains was 7.2 yesterday, now it's 7.5 today. I had previously increased my TA from 45-50 to 80, then of course the pH was up, 8-8.2 so I corrected it.
I know my CYA is getting even lower, being at 30-35 before the rain, so I was going to ask since I do need to increase the CYA, and I do need chlorine, I was going to drop in a some pucks to raise the CYA to 50ish, knowing that w more rain and only using the TFP method of 8,25% liq bleach, the CYA will again be lowered. I know this is taboo, but does anyone have a make/model puck and where to procure about a dozen that I can use over the next 1-1.5 yrs? I hear that 1 puck deploys 3PPM CYA for a 10K gal pool. so each puck would provide me 2PPM w 15K gal pool. I appreciate your help and support.
Thank you and pls advise, tstex
