Thread: More rains for Houston, Montgomery, Fort Bend and others. Brenham w 23" of rain
    Houston, TX
    1,104
    Hello to All,
    OK, my CA has been diluted, my CYA has been diluted, my FC has been diluted and so has everything else. But, rain water is tops. So, all this rain [this time] is done, I will post my results and see what things I need to do to keep all well w my CSI as too.
    Best to all,
    tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: More rains for Houston, Montgomery, Fort Bend and others. Brenham w 23" of rain
    it's crazzy isn't it, I have had to drain over 6 inches out just to keep it at the top of the skimmer..
    Houston, TX
    1,104
    we'll my pH prior to rains was 7.2 yesterday, now it's 7.5 today. I had previously increased my TA from 45-50 to 80, then of course the pH was up, 8-8.2 so I corrected it.
    I know my CYA is getting even lower, being at 30-35 before the rain, so I was going to ask since I do need to increase the CYA, and I do need chlorine, I was going to drop in a some pucks to raise the CYA to 50ish, knowing that w more rain and only using the TFP method of 8,25% liq bleach, the CYA will again be lowered. I know this is taboo, but does anyone have a make/model puck and where to procure about a dozen that I can use over the next 1-1.5 yrs? I hear that 1 puck deploys 3PPM CYA for a 10K gal pool. so each puck would provide me 2PPM w 15K gal pool. I appreciate your help and support.
    Thank you and pls advise, tstex
