Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: P.s.i after solar installation.
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    ok. I just installed 450 sq.ft of solar panels by heliocoil 10 panels.
    Before solar: filter read 12 psi with new filter.
    After solar: 21 psi.
    So after adding solar I gained 9 psi and the water return to the pool seems a little slower or should I say less pressure.
    Question is this too much psi? What is normal for psi after installing solar and what psi is dangerous.
    I'm running a Hayward super2. 1.5 hp
    Thanks Todd.
    15,000 gal. In ground, sand textured with beach area, spa located in beach area with spillover equal to pool level.Rock waterfall with 4 foot drop.Hayward goldline aquaplus automation all wireless remote.T 15 cell,Propane heater,Super 2 for pool/spa,Super 2 for waterfall.Cartridge filter and solar panels.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: P.s.i after solar installation.
    It depends how high above ground level are the solar panels?
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Quote Originally Posted by Isaac-1 View Post
    I would say 12 to 15 feet
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You installed the panels in parallel and not series correct?
    9 PSI would be a little high for 450 sq-ft if they were installed in parallel.
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Quote Originally Posted by mas985 View Post
    Do I need to worry about anything?
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Assuming the panels were installed correctly, you can mitigate the pressure rise by bypassing some water around solar.
    Having the excess pressure could possibly cause a leak but it is best to consult the manufacturer recommendations.
    Mark
    Mar 2013
    Yucaipa CA
    87
    You didn't answer the question. Did you install them parallel or in series. Parallel would be if when the water gets to the panels they split off running through each panel and then collect back together again to drain back to the pool. In series would be the water travels through the first panel then to the next then to the next and so on and so on.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Quote Originally Posted by skeeter_ca View Post
    skeeter
    Parallel
    Thanks Todd.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In that case are they being fed from one lower corner to the opposite upper corner, and are they slightly tilted (outlet side of each panel 1/2 to 1 inch higher than inlet side) so air is not trapped in the panels?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Also, what size pipe did you use to feed the panels?
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    It was professionally installed and two inch pipe.
    My main question is how much filter pressure is too high?
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,737
    IMHO 9 PSI is way to high for the that setup and those panels. 10 panels in parallel with 2" pipe should have very little pressure rise and 3-4 PSI would be more reasonable. If it were me, I would try to figure out why the pressure rise is so high. But if you don't want to do that, just bypass some of the water so the pressure rise is 3-4 PSI.
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just because it was installed by a "professional" does not mean it was installed right.
    mas985's Avatar
    Pleasanton, CA
    11,737
    +1
    Also, if you have the panels installed on two or more roofs, the panels may be in parallel for each set but the sets may be in series which would explain the higher head loss.
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    I do know that each panel holds 2 gallons of water so that's 20 gallons in the panels plus whatever the 2 two inch pipes hold.
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I don't follow. Volume of water does not affect PSI.
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    It is set up on two sides of the roof. With 7 panels on one side and 3 on the other side. So if this explains the rise is it a problem?
    +1
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It could if the installer installed each panel set in series instead of parallel. Does the output of the first panel set feed the input of the second set? OR does the supply line split and feed each panel separately and then their outputs are combined and sent back to the equipment pad?
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Input line feeds the first set of panels and then it splits off to the second set. Then first set outputs into the second panels output then comes down
    Thanks Todd.
  20. Back To Top    #20
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    So I guess that is in serries. Right?
    Thanks Todd.
