Results 1 to 18 of 18
Thread: Started SLAM on Swamp Thing
    May 2016
    Chesapeake, Virginia
    26
    Original Post:
    http://www.troublefreepool.com/threa...on-(updated-s)
    My last set of #'s BEFORE SLAM.
    FC 0
    CC 0
    PH 7.2 Base demand 1 drop
    TA 80
    CH 150
    CYA <30
    Early this morning I added 4oz. of sodium carbonate and 3oz. of stabilizer. Ran pump and filter all morning.
    Finally started my SLAM around 12:30 this afternoon. Went in heavy with 128oz. of 10% liquid chlorine.
    Almost immediately pool went from brown/green to cloudy green. (Made the mosquito larvae standout like a soar thumb) Visibility is maybe 1-1.5' out of 4'.
    Checked FC & CC in approx. 2 hrs and...
    FC 1
    CC 1
    Added approx. 75oz of 10% to get FC back up to 12ppm.
    Will backwash this evening and continue to run filter. Still some small leaf debris on bottom when brushing. Will continue to brush and skim often.
    Good thing I got started on this today. It's really sunny and hot out. Algae would have surely been even worse tomorrow.
    15' Above Ground, 4' water depth - approx. 5300 gallons.
    Hayward 1HP Pump-60gpm and 100# Sand Filter. Taylor K-2006 Test Kit.
    Loving our little trouble-free pool.
    May 2016
    26
    Re: Started SLAM on Swamp Thing (Looking a lot less swampy!!)
    6:50pm (4 hours after SLAM start)
    FC 5.5
    CC 1.5
    CYA >30 (wondering if 3oz. dry CA I added this morning has dissolved yet? Was hoping to be at 30)
    Added more chlorine to get it back over 12ppm. Will backwash filter tonight and continue to run pump overnight.
    Guess I'll check CYA again in the AM and see if I need to add more CA.
    Color is looking less green but very cloudy. Visibility remains at 1-1.5'
    Aug 2015
    Folsom Prison, CA
    124
    CYA takes a day or two to fully dissolve. How did you add it to the pool? Re-check your target SLAM FC after your CYA level is stable, and keep SLAMing and filtering until clear.
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Apr 2016
    San Diego, CA
    115
    CYA can take a couple days to show up in the test. How did you add it?
    11,500 Gal Fiberglass IG Pool. Hayward cartridge filter with Pentair 3/4 HP pump
    500 Gal Fiberglass AG Spa with cartridge filter
    Taylor K-2006 test kit
    May 2016
    26
    Added to the skimmer since I knew I would be running it 24/7 over the weekend. Guess I should hold off on backwashing as long as possible. Circulation is surprisingly good.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Don't backwash until the CYA shows up on the test or you might lose it. It will take at least a few days for it to dissolve.
    May 2016
    26
    5/28 6am
    FC 9
    CC 1.5
    Sorry pooldv,I backwashed this morning. Circulation was pretty low.
    Will check CYA later this morning when I have more time. Might add some CA in a sock to skimmer basket if it's still low.
    Water is getting better but still very cloudy and lots fine debris. Can see a few patches of leaves on the bottom that I missed when vacuuming. Scooping them up stirs up more junk unfortunately. A little heartbreaking but it will get there.
    Thanks for all the info and replies.
    May 2016
    26
    5/28 10am
    FC 10
    CC 1.5
    CYA >30
    Added enough chlorine to get back up to 12ppm.
    Added 4oz of dry stabilizer to a sock in the skimmer.
    Used leaf rake to get all the remaining big leaf pieces off the bottom.
    It's starting to sparkle a little bit. at least the top 6" or so!! Getting excited!
    DFW, TX
    24,485
    Nice work!
    May 2016
    26
    5/28 2:45pm
    FC 8.5
    CC 1.5
    CYA >30
    Added chlorine to get FC up to 12 or higher.
    Water quality continues to improve but still very cloudy.
    5/28 9:30pm
    FC 10
    CC 1
    Will check CYA in the AM. Hoping to see it at 30 finally.
    Rain coming tomorrow and Monday so hoping to get in the final stretch of this SLAM tomorrow.
    Anything else I need to be mindful of towards the end of a SLAM?
    May 2016
    26
    5/29 7am
    FC 12.5
    CC 1.0 (could tell it is close to being under 1.0)
    CYA >30 (still under 30, should I be concerned that my CYA is not coming up?)
    Water quality continues to improve. FC seems be holding more. I'm sure I'm on the right track other than CYA.
    Will keep brushing, skimming and filtering.
    SLAM has been relatively simple and painless. Patience is DEFINITELY a virtue. My wife is getting anxious. Hoping we can swim later this week or maybe next weekend.
    May 2016
    26
    5/29 12noon
    FC 11.5
    CC 1.0
    Will check CYA again late this evening or maybe tomorrow morning.
    Starting to get some of the tropical storm rain. Hoping it won't dilute the pool too much while I'm in SLAM mode.
    May 2016
    26
    5/29 4pm
    FC 8
    CC 1
    Added 32oz. of chlorine to get FC back up to 12
    5/29 10pm
    FC 11.5
    CC 1
    no chlorine addition tonight. Will check again in the AM and see how much drop I'm getting still.
    Need to brush the bottom really good and get everything stirred up good. Ready to get this SLAM finished up. Water feels and looks inviting. Other than the pretty strong chlorine smell.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    Hi! I just found your thread. You are doing a great job so far. The color is looking better with each picture. Keep the SLAM up. I am sorry to say the last part seems to be the longest part-------finial clearing to a jewel. It WILL get there. Just keep the FC up and the pump running.
    IF you have some time to babysit the filter you can add some DE to it. BUT you have to be there for the first couple of hours to make sure it does not cause too much of a pressure rise.
    Pool School - Add DE to a Sand Filter
    This will help filter out the fine stuff.
    Kim
    May 2016
    26
    Thank you. Unfortunately we are getting heavy rain from the tropical storm now. Pump is running but the pool is way full. Gonna try to test and keep FC up but we'll see how that goes. I'm sure CYA is gonna be WAY down again. UGG.
    Jul 2012
    Tallahassee, FL
    30,492
    Be careful! That one is packing some rain for sure!
    Kim
    May 2016
    26
    5/30 9pm
    FC 9
    Added chlorine to increase FC to 12
    5/31 7am
    FC 11
    5/31 12 noon
    FC 10
    CC >1
    CYA is still under 30.
    Added 4oz. of dry stabilizer to a sock in the skimmer.
    Added chlorine to increase FC up to 12.
    Was glad to see CC under 1. One of the criteria for finishing SLAM if I recall correctly.
    And the water is getting much clearer by the hour. Should be able to see the bottom soon.
    Hoping the rain forecast is less than predicted.
    Jul 2012
    Tallahassee, FL
    30,492
    What?? your pool has a bottom??? Not so sure about that LOL You are doing a great job!
    Kim
