Results 1 to 8 of 8
Thread: New leaf canister, Do i need an adapter?
    Mar 2013
    Yucaipa CA
    87
    I just received my new Hayward W530 Leaf canister. I seemed to have noticed a problem. On the inlet side where I attach the hose coming from my vacuum head there are two notch's that look like it would keep me from sliding on the vacuum hose. The Owner's manual that came with it says there are two adapters available but don't say where they work. The first one shown is the AXV098 and the second is the AXV092. Neither appear to be able to lock onto those notch's. How do they work?
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New leaf canister, Do i need an adapter?
    your hose should just slip on to the ends of the adapters, mine is not the hayward but I had the adapters in the box..
    Mar 2013
    Yucaipa CA
    87
    Ok, I guess I used the wrong word. They aren't notch's on the end they are tabs sticking out that would keep the hose from sliding on. see picture
    skeeter
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    I have that canister...on mine, the hose gets pressed inside the top hole, not over it.
    but the one on the other side is smaller and the hose goes outside/over it.
    works with existing hayward navigator cleaner hoses as well as vac hose without an adapter.
    if your hose won't fit then you might need to try both.
    Dolphin E10 Cleaning Robot.
    Mar 2013
    Yucaipa CA
    87
    Ok I was wondering that because they do look slightly different. I'll check as soon as I get home.
    skeeter
    Mar 2013
    Yucaipa CA
    87
    Well I checked it with my hose and it fits over the output end but is flush with the input side. It won't go over it or inside of it. See pics. Looks like I need an adapter. Is that what the AXV092 adapter listed above is for?
    skeeter
    Apr 2015
    tucson, arizona
    1,120
    Use the white plastic adapter, one end in your vac hose the other in the cannister
    Jul 2013
    Fletcher, OK
    3,353
    yep, thats exactly it..
