Thread: CC test
    Apr 2014
    Brookfield, CT
    17
    CC test
    It seems that my water always turns a very faint pink after adding reagent R0003 that clears after adding one drop of R0871. Does this mean I always have a very low level of CC, or is this normal?
    21' x 41' vinyl in ground pool, 26500 gal. 1 hp Hayward pump, 4 wheel suction side The Pool Cleaner, Hayward EC-75 DE filter, Hayward SUMXL 140 heat pump, TF100 test kit with stirrer.
    Jun 2014
    15,023
    Re: CC test
    Our pools are constantly transitioning FC to CC and waiting for the sun to oxidize it. That faint appearance might also vary at different times of day, so I see nothing to be concerned about. We treat CC readings at 0.5 or less as zero, so you are just fine.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CC test
    I get a very faint pink from time to time as well. Usually when I've left my solar cover on for days at a time with little sun directly hitting the water to help burn off CCs.
    Isolated Spa - 345 Gallons
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: CC test
    The only thing I would add is ensure you never drop below the recommended FC level for your CYA level. Otherwise... Well just don't let it happen!..
