Results 1 to 7 of 7
Thread: Question - Mats under pool and pavers under legs
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    I know I have another thread going with the progress of the pool, not sure if questions get lost in that though...the mods can tell me if multiple threads are a no-no
    Anyways, I saw suggestions about using the Harbor Freight Anti-Fatigue mats under the pool and went out and bought a bunch of them, but searching I can't find anything about if I should tape them together.
    Also I have the Ultra-frame round pool, last time just had the legs on the ground, but I have bought the 12"x12" pavers to put under the legs. Are these good/necessary? And do I cut away the mat from where the legs go, or can it be ground ->mat -> pavers.
    Maybe I am over thinking this?
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    Re: Question - Mats under pool and pavers under legs
    Anyone? Anyone?
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Yes the pavers are necessary, otherwise the legs tend to sink in the ground. Several of mine were 3" below grade by the end of last season. I would cut out the mats where the pavers go, in an attempt to keep the top of the pavers and mats at nearly the same level. Yes, I would tape the mats together.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Apr 2013
    Sacramento, CA
    2,769
    Yes Tape the mats together
    Jun 2016
    HOUSTON/ TEXAS
    42
    How did things work out for you?
    I have the exact same set up and wondering how the mats worked for you?
    Many Thanks & Great Days to All
    Miniman
    6981 Gallon 18 x 52 Intex Ultra Frame AG, Intex Krystal Clear Sand Filter Pump 3000 GPH, INTEX 120V Krystal Clear Saltwater System, TF-100 Test Kit, Intex Auto Pool Cleaner
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    340
    i plan on taping mine together with Gorilla Tape.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    chayne's Avatar
    May 2016
    340
    Well I did put the mats under my pool. They turned out great. Still had lots of cushion while walking in the pool. I was actually shocked. I was not expecting that much cushion with all that water on top. I think I needed up buying 16 packages of 4. I cut around where my pavers are located. Then after pool was up and filled I went around and trimmed the over hang off.
    Charles
    Coleman 16'x48"
