Thread: Sand in pool
    May 2009
    Trenton NJ
    497
    Sand in pool
    Is it normal to get some sand in the pool? I noticed when I clean out my robot there's sand in the bag.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Apr 2013
    Sacramento, CA
    2,769
    Re: Sand in pool
    You shouldn't be getting any sand from the filter in your pool.
    Have you done a deep cleaning of the sand filter?
    Deep Cleaning a Sand Filter
    Deep cleaning Intex sand filter - YouTube
    Lets try that first.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Sand in pool
    Depends on where you live. If you live in Victorville, CA or Phoenix, AZ or anyplace with "Dunes" in the name, I'd expect it.
    If you think it's coming from the filter, rubber-band a hole-less sock over the returns. If the sand doesn't reappear after vacuuming it up but the sock is full of it, you know it's internal.
    May 2009
    Trenton NJ
    497
    Re: Sand in pool
    I never deep cleaned. I wish I thought of that before I opened n got everything running.
    I live in Jersey ( 50 miles from nearest beach) so it must be from filter. I hope it's not a broken lateral. The filter is about 4 yrs old. I never changed the medium. It's called echo glass. Ever hear of it?
    By the way u guys are the best donate your time like u do. We really appreciate it!!
