Air Bubbles in Pump Strainer Pot
ned8377
0
250
Wake Forest, NC
Anyone know what would cause a slight amount of small bubbles to be in the pump strainer when I started the pool today. Closed everything except the main drain and they went away. Opened each skimmer individually and waited - no bubbles. Still no bubbles after an hour. The pool was shut down last night as usual and water is slightly more than half way up the skimmer. Thanks!
So, I went and checked again and still no bubbles. Turned the pump off and waited a minute and turned it back on and now small air bubbles again. Do you think it could be maybe the gasket on the top of the strainer? It seems like air may be getting in right when it is turned on and there is a change from no pressure to normal run pressure.
