Thread: Current results (bromine), what to fix first?
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    As of this morning we have not used it since switching to bromine as Br level has been too high
    pH 7.5
    Br 15.75? (Using FC test from TF-100, 14 drops*.5*2.25) added 2 oz hydrogen peroxide yesterday, should I add 2 more?
    CH 100 (s/b 120-150) add hardness or am I close enough?
    TA 30 (s/b 100) add baking soda?
    Temp 100
    Borates not added yet (s/b 50)
    What order should I fix these? Do I need to wait for one to be correct before I move on to the next?
    Liz
    17,500 gal, IG Trilogy fiberglass sport pool 43'8"x16', Jandy Cart CS Ser filter, Jandy Pro Ser+ 1.5 HP pump, Nature 2 Fusion Soft SWG (mineral removed), TF-100 test kit w/ SpeedStir, Dolphin Oasis Z5 robotic cleaner. Maax Spa 481 (455 gal)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Current results (bromine), what to fix first?
    Is this for a spa or pool? CH is probably OK, if it foams up any then increase to 150. TA should be more like 50 or 60 , raise it to 50 now. Test PH in 15 minutes and adjust to 7.6.
    I don't know much about borates.
    For a spa, read this for the good info on managing PH, TA and borates, How do I use Chlorine in my Spa (or pool)?
    Edit: just noticed this is in the spa forum
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Quote Originally Posted by pooldv View Post
    Sorry it's for a spa, didn't think to specify that
    Liz
