As of 11 am this morning
pH 7.8 (top of the range should I do anything?)
FC 5 (SWG running at 30% for 12 hours)
CC 0
CH 200 (s/b 220-320)
TA 70
CYA 40-50 (TFPC s/b 70-80), SWG recommended level 10-50, pool store rec 40
Salt 3300
Borates - not added yet
Temp 75
Based on the above I need to add hardness, stabilizer and borates, in what order?
Do I wait on one to be right before moving to the next one?
Can/should I reduce the SWG % or run time?
I've added the recommended stabilizer twice (weeks apart, last time a week ago) I started at 30 CYA, should I keep adding? Does water temp affect the reading?
Does water temp affect the salt reading too? I've gotten a range of 2900-3300
Anything else you see based on the above? Water is sparkling and clear, very inviting
CC 0
TA 70
Salt 3300
Temp 75
